Truck doesn't go into gear
Dennis.max
Apr 12, 2017
7
I have a 2001 Chevy Duramax has the Allison trans. Wouldn't move the indicator on the dash would just flash so changed the nsbu switch and no difference, had the tcm flashed and reprogrammed and still nothing so I changed the ignition switch and the truck then went into gear but took a few seconds before it kicked in then went back to not moving and just flashing on the dash. Also if I unplug the 4 pin wire connector on the nsbu switch the truck will move but only in limp mode. Any help would be awesome this truck has had me spinning for awhile now :confused:
Dennis.max
Apr 12, 2017
7
I can get the truck to move but once I do I can't go far and it will just quit moving and the gear selection flashes but truck won't move unless I cycle the key a few times
5,911
You have codes, you just have an electrical issue going on that needs to be address. Start at the Tcm and follow the wiring back looking for frayed or cut wires.
Did you put the nsbu in as the instructions stated?
Dennis.max
Apr 12, 2017
7
Yes I did and checked all the wiring the dealership I took it to to get tcm flashed look over the wiring as well and didn't see any problems
