Truck Dies at the End of the Track?!?!
Oct 16, 2008
948
12
Idaho
I pulled again this weekend (3rd time ever). At the end of the track when I got out of the throttle the truck died. It's done this every time I've pulled and it starts right back up but I was wondering why it does this? Stock turbo, 50 hp sticks, and EFILive. I don't think this is very good for the truck and was wanting some thoughts/opinions/suggestions. Thanks guys.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
the converter is locked, and when you let out of the throttle really fast, the wheels suddenly stop spinning. TCM doesnt have a chance to unlock the converter fast enough before the wheels stop spinning so it stalls the engine. Same thing as if you slam on the brakes (and lock up the wheels) on a manual trans car without pushing the clutch in.
try throwing it into neutral as you let out at of the throttle at the end of the track, or dont let out of the throttle so fast.
ben
Oct 16, 2008
948
12
Idaho
ben
Thanks man. I didn't think about the converter, I don't think I'll try neutral, seen too many trucks go for it and hit reverse. I'll try to let out easier. Probably not the best for the truck when it stalls.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
that doesnt matter with the allison.
Next time you are on the highway, try shifting into reverse :)
(nothing happens, it just goes into neutral, its great for getting rid of tailgaters thoguh because the reverse lights still come on)
paint94979
Beer Nazi
Sep 18, 2006
11,715
37
LOL thats a good one Ben:happy2:
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
at 10 mph and 50%tps my truck will go from D to R :eek: and it hurts
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
was it in limp mode? Do you have a 6-speed conversion TCM? Something must have been wrong or it must have been throwing a code...because anything over like 10% throttle, 900rpm (engine speed) and 200rpm output shaft speed will inhibit a neutral to range or range to range shift. Its programmed into the TCM and theres no way for it to be bypassed unless its in some sort of limp mode.
ben
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
was it in limp mode? Do you have a 6-speed conversion TCM? Something must have been wrong or it must have been throwing a code...because anything over like 10% throttle and 200rpm output shaft speed will inhibit a neutral to range or range to range shift. Its programmed into the TCM and theres no way for it to be bypassed unless its in some sort of limp mode.
ben
No 6speed tcm and no cel but it may have thrown a code i never checked. I just know it was not fun:( i am very careful when i throw it in neutral now
aggar
Still Learnin!
Mar 9, 2008
444
Kirklin, IN
When I pull and get to the end I have my hand open palm and push forward on the lever and it goes right to nuetral everytime. I was nervous the first time too but it turned out ok.
jneal
Feb 12, 2008
294
Bloomington, Indiana
X2, I tell everyone that asks me the same thing. Open palm the shifter and push forward and up at the same time. As long as you don't wrap your hand around the shifter, there is very little chance of going to reverse. And like Ben said, if you're rev'ed over 900rpm, it won't go anyway.
Don't worry if it does though, the sled will stop you from going to far back.:D
