Truck cuts off at high rpm
3,733
305
What areas should I be looking at? Also I cant get the dashboard to work on the scan tool any trick to it?
I personally just use black box logging, so you can leave the laptop at home if you want.
I would record desired rail pressure, actual rail pressure, throttle position, engine rpm, vehicle speed, and injector pulse width.
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
when you log the truck, just select the pre loaded imperial pid selection file. this is generally enough info for basic diagnostics.
Mdmax
Aug 30, 2009
29
Recorded a couple sessions, Is there a way to post it up on here so you guys can look at it? Do I need a memory card to record with the black box?
Mdmax
Aug 30, 2009
29
bump someone help me before I set my truck on fire. the logs dont seem to mimic what im seeing on the tach. Cant really tell anything is happening.
13,746
821
You can put the logs in a zipped folder and attach it to a post.
Mdmax
Aug 30, 2009
29
Heres one hopefully it works. I really appreciate any help I can get. thanks
  • Log_0002z.zip
13,746
821
Frame 122 shows a sharp drop in both MAF and boost pressure. Can you get another log that shows vane position?
Mdmax
Aug 30, 2009
29
Ok got 2 more logs with vane pos. and a few more pids that may help. I noticed on this one the difference in rail pressure was off almost 2k psi. Is that normal? Another thing right when it cuts off theres a big hiss and a huge plume of light gray smoke.
  • Log_0004z.zip
  • Log_0005z.zip
disspose
May 25, 2013
12
Anything else? Did you ever find the problem? I have a LB7 and it was jerking/cuting out at 2500-2800 in every gear.... I need help....!!
disspose
May 25, 2013
12
No Codes
Parts changed...
Fuel filters
Fuel pressure regulator
FICM
ECM
BCM
Crank and cam sensors.
Went to stock tuning- still does it
Use a scan tools snap on... watch while it does it and everything looks fine.
I am lost.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
Dont go throwing money at this thing on account of what I say, but I helped diagnose a truck a while back, LB7, it was doing some crazy things. Limited to 2000 rpms, falling on its face and it was bone stock. It didnt set any codes which made it difficult. Ended up being the Cp3.
disspose
May 25, 2013
12
We have unplugged the insight... Hence how would we plug a scan tool in??
Lwatson.... We are swapping out parts off a running lb7.. So I am not buying all of those.
ALso.... It holds rail pressure when turned up with a scan tool. Did that one you fixed hold it up to 23k?
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
At idle it holds rail pressure when commanded up, or it holds through the whole rpm range? I have a weak CP3 that will hold pressure at idle, but barely holds pressure at higher revs.
LWATSON
Jul 30, 2008
2,587
55
Scotland Neck NC
We did not check rail at idle but under throttle it would only hold about 14k.
disspose
May 25, 2013
12
It holds it when commanded by the scan tool and while driving.
Desired vs actual is basically the same.
disspose
May 25, 2013
12
Another guess we have is if one of the injectors ir grounding out or failing, it would take out three other ones as well on that string. But the weird part is that should set a code. No codes are ever given with any scan tool we use(insight or snap on) or even a dealers.
