LLY: truck cranks for like 5-6 before it will start issue, WHY?
kvw4x4
Oct 7, 2015
47
it cranks quite a bit longer then normal, it will start everytime just takes awhile, letting it sit for a couple days doesn't effect how long it cranks to start, we rebuilt the fuel filter head, one thing I noticed before and after the filter rebuild is that the primer pump never hardens up, any suggestions?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Injector return rates are probably high. Lift pump will help a little. (Bandaid)
Dozerboy
4,892
470
TX of course
You might try a new filter head. I think mine cracked or something rebuilding it never helped. Lift pump would help it start if that the case too. It’s just going to leak fuel until you replace the filter head.
kubitza123
Sep 19, 2016
144
Texas
I'd buy a new filter head before I even thought about replacing injectors. Is it something that just happened within a couple of days or been gradually getting worse over a year ?
If just started happening I'd bet filter housing has a problem.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
A clear piece of fuel line between the filter housing and the test port would give you your answer real quick if the filter head is an issue or not. I would moreso expect a start than stall from a cracked filter head though.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Explain please
Install a piece of clear fuel line between the fuel filter and the T block that goes to the test port. If it is the filter housing leaking, you'll see an air pocket form in the clear line. If no air bubble/pocket forms, then theres no air leak. You can normally pickup clear vinyl tubing at a hardware store for a $1 a foot.
ikeG
Oughta Know Better
Apr 19, 2011
2,464
147
Western PA
www.facebook.com
Cool deal. Thanks for the tip
Robby Avery
GM TECH @ FENDER GMC
Jul 31, 2008
820
Norman Park, Georgia
Fwiw Just something to think about there is a thread on here that is related to fprv on the lb7. it can cause low rail pressure during start up hot or cold ppe makes a plug to address the concern it is associated with a p0087 and may set a p1093 it's cheaper than a $700 gm fuel junction block as well as a filter head from the dealer if its not leaking. If high injector return rates are the culprit the only way to address that is overhaul of injectors if bodies pass inspection and flow test or r and r injectors. keep us updated curious as to what is found
kvw4x4
Oct 7, 2015
47
One thing we figured out. With the weather getting colder here it started to get a lot harder to start. We plugged the truck in for 12 hours and after being plugged in the truck started very quickly.
kvw4x4
Oct 7, 2015
47
I would like to bump this up a bit. Adding if Truck is plugged in overnight it starts a lot faster. Not perfect but faster. The truck was at dealer. Fuel holds pressure to filter seems to have an issue on high pressure side. There were a couple injectors that were close to
+\- 4, dealer wrote still has long crank high psi side only ramps to 11,000 psi, checked pressure relief valve that was ok.
Attached is notes from dealer. Including balance rates
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Sounds like high return rates on the injectors.
It start better when plugged in because it is cranking over faster so the CP3 pump is spinning faster.
New battery's, fresh starter, lift pump, will all help aid starting and act as a band aid. But more then likely it won't start good until you replace the injectors.
