Triple S472's
BSdiesel472
Smoke
Feb 24, 2015
47
Southern Pennsylvania
I do like that though. It's different. Would it be easier without the big intake?cause I might consider it. Already built my pedestal but I would jus have to cut it apart a little bit
quadracer37
Mar 31, 2009
547
northern, IL
3-s400's remote mounted to allow runner intake
3- s300's
S Phinney
4,008
Quncy, Fl
Piping is 4500 and up depending on options like v bands and Dual seal clamping and different material specs and finish. Turbos are extra. Cheaper side totals 7500ish. Optional side 12k.
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
Im into aprox $1700 all in.thats 2 475 83 90,s and a a 475 87 1.1
valley,clamps,flanges,ped,ect.Its all the little things that add it up quickly.
S Phinney
4,008
Quncy, Fl
No disrespect meant at all but each kit just can't be thrown together without careful consideration and choice of parts. If done without that it will not perform to expectations 95 out if 100 times. Your price on parts would imply that you are using cheap out if the box units. They may work ok together and they may not. I can guarantee you they will not perform like a well designed and spec ed kit will. Good luck with it and again this isn't intended to be defamatory in any way.
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
None taken.i did speak to Mark before anything was started,i did w@nt to add that 2hat i am doing prob wont work as well as a speced kit but it can be done.Those guys do exceptional work.
