I know this has worked as in 07 or 08 Kyle at Ciud had Triples on climax and is currently running them on the new climax.
Yeah their are a handful of pull trucks in our area that have been running them for a little while now
Looks nice, do you guys underdrive them? We had close to enough fuel out of 2 stockers until the engine went above 4200rpm... Then the stock ones start to airate a lot or something it seems like. Or with 3 is there enough volume the airation doesn't matter.
if your running a twin pump setup you probably don't have your 3200rpm rev limit on your engine anymore! So all your doing is over working the pump.
X2. I like the look of that pulley.Can you buy one of the pulleys you are making ? If so what kinda $$$??
Built motor , duel fuelers , 60's overs , gtx4202r
i must be that select few who keeps it at the factory rev limiter
That looks familiar, nice setup good luck this year. Your plumbing looks a lot better.
just talked to him yesterday about these for overkill, what a nice piece of work, duals are out hahaha with a set of those twins on top, one just seems so lame now :roflmao:
How big is big?
