Trents twins or triples with ATS manifolds clearance issues?
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
39
I'm looking into purchasing trents twins or maybe even some triples in the near future. I am running ATS manifolds and up pipes which are quit a bit bigger that the stock ones. My question is will the downpipe or downpipes (triple kit) have any clearance issues with the ATS manifolds/up pipes? any turbo mounting issues? Can I still run fender liners with the triples? Being in New England I need the to keep sand and salt out.
paint94979
Beer Nazi
Sep 18, 2006
11,715
37
With twins the downpipe will not hit the up pipes I'm sure tripples will also not be an issue
MuscleTruck03
Wants a turbo!! or two...
Mar 10, 2010
369
north ogden, ut
I dont know about the triples but the twins you'll want to wrap the down pipe and may have to put a little "buldge" in it to give the down pipe a little clearance
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
In either setup the fender liner needs to be slightly re-shaped or notched , a heat gun can reshape it with no notching , mine is notched and in Utah I am in the same boat , salt all winter and it doesn't let anything in , manifolds are not an issue , all of my down pipes are designed to work with aftermarket manifolds , no turbo mounting issue's either , and yes the triples keep the liner but do need some trimming , I'll post some pics up of one trimmed after this latest set is fully installed should be no later than Monday or Tuesday .
tractor
293
9
59
Spring Creek,NV
Sledhead my truck is in mass.I will be going back to pick it up around the middle of the month if you want to look at trents twins to check it out for yourself.
Darryl
Sledheadxp800r
Dec 13, 2010
1,151
39
Darryl
I'd love to check it out. What part of mass? Im in the far northwestern side of CT.
Sledheadxp800r
Dec 13, 2010
1,151
39
Thanks man pics are good. Thoes things look awesome. What do you run for exhaust with the tripples dual or do you have some kind of Y-pipe fabbed up?
Pondsy
Jan 4, 2008
641
53
Plymouth, MA
Darryl
Lexington.
Also go to the cape,they have a home there also.
Hey Tractor - if you put something together when you come back, I'd appreciate it if you let me know. I've ordered the tripples, but would love to see the twins in person and go for a ride. I'm in Plymouth, just before the bridge.
Later
Bill
Pondsy
Jan 4, 2008
641
53
Plymouth, MA
God deal...let me know when you head down this way this week. So long as it's not Tuesday, I should be able to catch up. I'll check with Noreaster as well since he lives on the cape.
