transmission problem
slowbuild lly
Feb 20, 2017
5
getting p0700 code trans gets stuck in 3rd gear then it wont take reverse or drive an says shift range inhibited. anybody have any suggestions to fix it? trans is built.
SoCalMike
758
SoCal
That code is a generic trans code. It just means something is wrong with the trans. There should be other codes with it.
Have you called your builder for help?
CarolinaHD
969
NC
P0700 is the standard code for a transmission issue, you'll need a better scanner like a tech 2 to find the actual P07xx code. Once you have those specific codes, we'll have a starting point.
Awenta
4,090
CT
700 means the transmission requested a check engine light. There are more codes. Strange though because the snap on usually get them.
Awenta
4,090
CT
Built by who and how many miles? If you're in third check the round plug in the transmission.
1,881
Moved into Mike's Transmission area. Be prepared, b/c he's going to rip you for not scanning the TCM further to find the rest of the codes.
minerigger
2,660
Casper, WY
I'm floored not one comment about sheep or him giving them the night off, besides I didn't know she could drive. I will say for as mean and scary as people think he is on here that mike is hands down one of the coolest people I've ever talked to on the phone. You'd swear you've known each other for years.
slowbuild lly
Feb 20, 2017
5
ok well it only randomly does it itll shift up through the gears fine but once in a while when u go to a stop sign itll get stuck an wont go out an then it wont take reverse or drive after that. and i built it myself.
