Allison 5sp: Transmission Autopsy after 1100+hp
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Pulled the trans today to send the converter off to be tightened up a bit and checked out ,took some pics and was pleasantly surprised with what was found ! there was not alof of passes on it so far , probably 15 passes and 10-15 WOT street runs that were equal to 1/4 mile passes . A big thanks to Mike for a setup that is working at these power levels and also sent you a PM with some more info , most said it couldn't be done , The truck will be back together for the Dougless WY race and the power may even be turned up a bit more , if money allows a bigger secondary ( PBK ) will be going on also :D but doubt it will happen as thats a big chunk of coin with out selling my S510
the clutch pics are in order c-1 - c-5 and snapped pics off all the planets they are not showing any signs of twisting so far ! here's the pics ......................
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
looks great trent! are you running stock input/output shafts? And if you arent running stock hard parts, what was the highest you tested stock allison hard parts to?
TrentNell
Jul 7, 2008
7,543
slc tuah
As of this point all the hard parts are stock but at 5500 lbs it def helps , money pending a billet output might find its way in this time down , would like a billet c2 hub also but doubt i will be able to swing it at this point , i wont replace the input unless it breaks .
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
fantastic trent!!!!!! i keep telling you that truck is gonna change the thought process on people who want to race on a 'limited' budget :)
my hat remains off to ya! :thumb:
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Trent, your truck is badass. Thanks for proving me wrong about the ally lasting at those power levels.
Thanks for posting.
05' Ditry Duramax
May 3, 2008
1,294
42
Port Orchard Washington
I'm impressed with how things look. I would have to imagine the weight of your truck will allow the hard parts to last slightly longer than in a DD. Anything can happen at your power level though. Good Luck!!
