Allison 5sp: Transfer trouble
Harleydoc
Jan 1, 2013
This is my first post here. I have an 2003 3500 and it seam like the transfer case is kicking in and out of neutral going down the road this is when it is in 2wd. If I get out of the gas for a bit it is kick back in an go fine for a while. I have not lights still waiting to check if there is any DTC in it. Any help would be great.
Thanks Will
Harleydoc
Jan 1, 2013
Ok so I pulled some history out of the computer today is is have a transfer switch malfunction and a switch malfunction. I guess I need to change the switch and go from there. Anyone have any other ideas
Harleydoc
Jan 1, 2013
I found the problem the transfer case looks like a bomb when off inside it.
Harleydoc
Jan 1, 2013
Now I am about to go and change the fluid in my wife gasser and my gasser as well. What would you guys run in a 2004 chevy suburban with full time 4x4 and 2002 chevy 1500 that has the auto 4x4 button? I run amsoils sever gear in my 4runnner but don't really know what would be the best for the gassers. I looks to me that the oil all slugged up and could not be pumped thur the pump and cause it all to take a poop.
Thanks Will
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
Well I guess for what I have found dex III for the duramax and autotrac for the gassers
That is what the book says, if you get another used trans be sure to put in a "pump rub kit", my guess is that is what happend to yours
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
X2 and i run the autotrac in my transfercase a good friend of mine at GM said to run it,its the best.Its pricey tho 6 to 8 a quart.
Harleydoc
Jan 1, 2013
I got a reman for a local guy here in town today that has being doing Lot do that thing and he has upgrade with pump rub stuff
Harleydoc
Jan 1, 2013
The fuild in the case was more like grease I was thinking someone put the wrong lube in it and could not lube it self
