My 01 duramax that has roughly 350k on itm just started spitting fluid out the vent hose from the transfer case. I just pulled it out of the truck to tear into it to see what it needs to be fixed. For those that deal with these often, what is most likely my problem? I was thinking either:
(1) The TC input seal is shot letting the trans overfill the TC or
(2) Something let go inside of the TC creating enough heat to make the fluid expand and come out the tube. I only say this because when i bought the truck it had the pump rub hole and no fluid in it.:thumb:
How common is it for the input seal to leak?
