Transfer case has been slinging fluid for as long as I can remember. Installed a new seal last year and it did not fix the leak so I figured the slip yoke bushing has worn beyond allowable limits. There is, in my opinion, to much play in the slip yoke when you push up on it.
Recently I have developed a vibration at 128+ mph that I am sure if I stayed in the throttle long enough, I'd be picking up broken piece of transmission and transfer case. It does it in 4wd as well as 2wd, right at the 128 mph mark.
Has a brand new Page drive shaft heavy wall rear drive shaft and all new spicer non greasable u-joints. Vibration is there with the stock rear shaft as well as the new shaft so that is not the culprit.
I am hoping that rear bushing has worn enough that it is causing the drive shaft to bounce around.
I just purchased a brand new aluminum rear case half for the transfer case. Hoping to kill 2 birds with 1 stone. Fix the leak as well as the vibration.
Has anyone experienced a vibration like I am describing from a worn slip yoke bushing? Vibration is not at all noticable normal driving, but hit 128+ mph and....yea.
