#PIP4151A: Transmission Or Transfer Case ATF Leak At Propshaft Slip Yoke - keywords 6L90 fluid LCT 1000 MYD MW7 NP2 NQF NQG seal - (Oct 3, 2008)
Subject: Transmission or Transfer Case ATF Leak at Propshaft Slip Yoke
Models: 2007-2008 Chevrolet Silverado 2500 and 3500 Series
2007-2008 GMC Sierra 2500 and 3500 Series
This PI was superseded to update model years. Please discard PIP4151.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some vehicles may have a concern of Transmission or Transfer Case ATF leak at the propshaft slip yoke welch plug. This condition may be mistaken for a leak from the transmission or transfer case output shaft seal. If necessary use automatic transmission fluid dye to help isolate the source of the leak. When diagnosing this concern, be sure to thoroughly clean the area and road test the vehicle to verify the source of the leak. The condition may be caused by burrs on the slip yoke welch plug, preventing a good seal against the yoke.
