transfer case electrical issues
HogAssWild
Nov 12, 2009
502
P0700
P0659
turn key on 4wd light comes on but goes off immediately..
drives for 4-5 min. fine shifts great all of a sudden limp mode..
change tcase solonoid and heat sensor.. same f*ckin problem
any fuses i can check?
TRUCK FOR SALE
_________________
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
P0700
P0659
TRUCK FOR SALE
_________________
:rofl:
keep in there man, you will get it figured out. You wil find the help you need here for sure.
Mike L.
15,681
232
Fullerton CA
I am still questioning the code number. First letter you gave me was a P and that does not make sense. Need a Tech 2 on this truck and you need to go into the Transfercase module.
HogAssWild
Nov 12, 2009
502
The solonoid goin back to transfer case needs power right?... no power
Does anybody know what all relays it goes through from the 4x4 button to tcase solonoid
Pulled every fuse in truck nothin blowed
Has to be a relay tripped
HogAssWild
Nov 12, 2009
502
what's that consist of...
I'm no mechanic by no means and don't try to be.... but I think that it may be transfer case control module, I found a burnt spot were the f*ckin wires rub up against the front driveshaft.. and it was thr actuator hot wire... so I'm thinkin it got the control module
HogAssWild
Nov 12, 2009
502
I had the truck runnin perfect for about 2hours... then wire shorted out and threw into limp mode
I did look it up.. and that will cause a powertrain limp
