If it is the LBZ in your sig, then it is probably a mismatch with your front pump seal and the Dex 6 fluid. The Dex 6 will destroy your front seal because of incapatability. Thank GM for that one.
:help:
What's the "right or best" fluid to use Mike?
I've had a nuisance leak since the day I had my trans built, never dripped a drop before that...
Took it back to the builder a year later and he tore it down and went through it and replaced the C3's I think, just cuz I guess, but he said everything looked great. As a precautionary measure he sealed every bolt head and the pump with RTV and it still leaks, about a U.S quarter sized drop every time I park it...
Other than the drip the truck shifts great and the trans stays cool, I was told to use, and he used Merc5 for fluid...
Thanks in advance for any insight
:hail:
