Just updating on this from the other thread.
I replaced the Pressure Switch Manifold per Mike's recommendation and while I was under there also replaced the NSBU. At 95k miles, I just figured good preventative maintenance.
The trans is still having issues and throwing the P0847 code.
If I clear the code I can drive around in 1st gear with no problems. It will then free rev for a second or so and clunk into 2nd.
When it comes time to downshift, the trans locks up (locks rear wheels up), throws the code, and the truck stops. No longer being able to move forward, only reverse, until the code is cleared.
Now Mike is thinking its a wire that has rubbed through somewhere causing electrical issues with the trans. The wire could be internal or external.
Just throwing this up here for any other ideas and for other to ponder on, etc.
