So truck has been kinda shifting hard into gear the last week or so and then down shifting from 4-3-2-1 it sometimes really shakes the truck. Doesn’t do it every time but every few times. Thought it was my a/c running as temps have got a lot hotter thus affecting the shifting/tuning. Well today I was getting a coffee and I noticed the engine temp getting warmer and warmer. As it climbed from 190 to 215 just at idle. So as I left it was stuck in 1st gear then would rev up and then all of a sudden it locked up and I could hear the rear tires almost skidding. Stopped, turn truck off for a couple minutes and it was fine. Whole way home it was normal then it stuck in 4th gear when I pulled into my development(no code). Really seems heat related but for the most part temps were within a hundred degrees of ambient 190-200. Any ideas? Truck is built lml in a lmm with built trans and compounds(1000whp).Also have a fleece alli locker and I def get my share of p0700 when it’s turned on. Disconnected it after today and it was still acting up. Thanks again.
Sent from my iPhone
Sent from my iPhone
