I've got the whole package on mine, still working out the bugs in the programming.
Current problem is the 3rd brake light camera looking down into the bed. I'll hold down the back button, select it, then put it in reverse to back under my 5er. Within 2 seconds the damn thing automatically changes to the tailgate camera.
Side mirror camera system works great, comes on with the blinker or manually. Haven't hooked up the wireless one for the back of my camper yet.
I have a 2017 GMC Sierra 3500 HD. Had the intellihaul system installed in January. Absolutely love the system. The backup camera does come with a mounting bracket and screw. You should wire to your running lights on the RV so that you don't drain the battery when not in use, also will extend the life of the camera since it won't be on all the time. The only issues I had with my system is when backing up the trucks backup camera takes over and you have to push and hold the "back" button on the dash to let it go back to whatever camera you selected to see. Also I have a 44 Foot Fifth Wheel Toy hauler so sometimes the camera loses signal. I think that's because the dealership installed my antenna to high up on the back window so the antenna doesn't point up, instead it points sideways. I would buy this system again tomorrow if I got a new truck. I absolutely love how much you can see with the side view cameras. I also got the optional stop light camera that goes in the bed and it helps tremendously when hooking up my fifth wheel.
