Traction Bars
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
I am looking a making a set of traction bars. Is there any advantage of running long bars over short bars, how much angle do you need to keep axle rap in check. Right know the truck is at stock height, but I may do 2 or 3in drop shackles and l am looking at using a set of fat boy newtons and just making rear brackets. Any thoughts? :hug: Also will air bags effect the traction bar or help them?
z79outlaw
793
Salem WI
If your gunna pull your gonna want long bars there's some trucks with severly damaged frames from running short bars, it acts as a fulcrum and the bend bad at the point there attached at.
Janimal444
354
Salem, NH
General consensus is long bars are better for sled pulling, short bars better for drag racing. As far as the angle, the closer the bar is to parallel with the ground the better.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
It looks like the guy before me did some sled pulling, because there is a little extra space between the cab and box. The truck will a dd, maybe some track, maybe some sled pulling.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
Is there a in between? I was thinking on doing a 3 link set up. Two long bars on the bottom and one from the pumpkin to where the old carrier bearing was. Do you think this will get the best of both worlds?
BBankDmax
Mar 24, 2013
Mchenry IL (815)
i run 68" bars on mine homemade and haul trailers all the time never had a problem .250 dom tubnig is what i used cost about $350 but totally worth it IMHO:thumb:
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
I would think you would have binding with the leaf springs
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
when i made mine i did bushing on one end and heim joint on the other end... since mine is a crewcab i chose to go about 60" which put the front bracket right at the first available flat part of the frame
Andrew
Costly Obsessions
Aug 7, 2013
275
delaware
Ive always been told they should go on the frame close to were the first u joint is located so that would mean different lengths for different wheel bases
