Woo that sixty needs some work. With that mph you will run 11s if you can get it to launch.
Once the tree starts you can leave at any time and still get a time slip, as long as it is test and tune. So don't worry about the light, just get your boost up and go when it is as high as you can get it. If you leave on boost you will definitely pick up a ton of time.I kept building boost on the line then it would push through the brakse so I had to let off. Then the tree would light and I'd have to go with zero boost lol. So it was like a crawl until the Chargers would light but then it seemed to haul ass.
Have you flushed the hydro boost lately? That greatly improved my brake firmness.
Yes definitely higher stall! Try leaving at less boost, for now.
