Trac bars
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I have bushed fronts and heims in the rear. I just have cheap eBay heims and they haven't locked up and don't make noise.
TIM Z
Screwed by 0087s
Jan 17, 2009
1,574
Navarre, OH
What sizes?
How are you guysw attaching the bars to the rear axle? Underneath the U-bolts?
Any all ready made brackets out there for DIY guys?
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
3/4" heims for me. Attatched to where the u bolts are. I cut my brackets from 1/4" plate iirc. Summit sells shock mount tabs that may work
SDP
AKA Dmax15
Dec 20, 2008
261
Port Angeles, WA
Here are some pics of mine, I used ballistic joints on one end and bushing on the other, both are greasable.
SmokeShow
6,818
Lawrenceburg, KY
dang those look nice...
if you go to duramaxracing.com (Mike Tomac's website) and look at his. I have those same rod ends, I just used 2"x0.125wall" square tubing instead of the round DOM like he uses. I'm not positive but I think Burkhardt stocks those same rods ends. They are from like semi truck track bars I think.
If you can't find those... places that sell offroad components have those ends like Dmax15 is showing on his. I think Ballistic is one of the manufacturers of them. If you get on Pirate4x4 and cruise the shops there, there's several of them that sell weld on tabs and brackets and all that kind of stuff.
C-ya
bonescarolfi
Sep 3, 2008
223
Marshfield WI
After digging around i think i might try summit brand 3/4 rod ends on both ends, qa1 tube adapters, and some 1 3/4" od, 1 1/4" id .25 wall thickness dom tubing and see if it holds up to pulling.
SmokeShow
6,818
Lawrenceburg, KY
If it were mine, I'd go bigger diam. on the tubing but I like 'em stout with little or no flex. To help with that, keeping them as flat as possible should help the round tubing with deflection. The more axial the loading on them, the better.
C-ya
bonescarolfi
Sep 3, 2008
223
Marshfield WI
C-ya
2" does cost a little more but i suppose might as well go over board the first time and not have to make 2 sets.
SmokeShow
6,818
Lawrenceburg, KY
ultimately, I'd go square tubing if I were you but if its gotta be round (I admit, it looks a little bit better being round) then I'd go for some 2"
And yes, square absolutely is stronger than round when talking about the compressive forces being applied and equal size outside dimensions.
C-ya
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
If you go to ballistics website you can buy the joints, mounts for them, and the weld in bungs. Pretty sweet setup and I priced some out to do just the fronts and I think it was $140. Theyre rebuildable too
blakem_85
May 28, 2009
You can use a square tubing that will be much stronger and it wont need to be 2" ID
You would have to use pretty thick-wall square tubing for it to be stronger. Every set of bars I've seen made out of square tubing have bent, both single bars and triangulated bars. The first set of bars i built for my truck were 1/4" wall, 1-1/2 box and were bent front to back and side to side. All the bars we build are now made out of either 3/4 i.d. DOM tubing or usually 1-1/2 i.d. DOM tubing with heim joints.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
If they are the same material and same size square is stronger. If you go to s larger round bar that doesn't mean it's stronger because it held up
