what are the best trac bars for pulling. i was thinking cal-tracs but just wanted to see what other options are good. thanks
dont use caltracs. ive heard of them bending and becoming junk on the pulling track. long bars are best. i have cognito's on mine. i love them because the have bushings at one end so they dont ride as harsh, but i dont think they are as good as the cutom ones with heims on both ends.
2" I.D. ? that's huge piping !
You can use a square tubing that will be much stronger and it wont need to be 2" ID
On a related note, I saw an 06 ccsb with a 4" lift and caltracs twist the driveshaft in half last night...major axle wrap.
Custom bars, 6'+ in length, like the others said seem to be the popular choice around my area. If your worried about running them on the street, all that I've seen are removable, just pull the bolts/pins.
I take it you were at the BUCK last night- that was some carnage! His truck doesnt have a lift though- but his Cal-tracs certainly didnt help him much. He got into a little rear bounce and kept it hammered down until the aluminum shaft twisted like a pretzel!
All of the bars that i have built for guys have been between 6'5'' to 7'3'' eye to eye depending on cab and bed configuration- using 2'' OD and 2 3/8'' OD tubing. GOOD LUCK_ Steven
