I have a tow tune that is about 100hp. If I wanted it to run a little cooler, can I just add a little timing or do I need to pull a little out of the pulse width?
I know with this tune that the timing was pretty low, lower than stock in the cruisin range
No, you are right, that one does have more than stock, in the cruising range. I was looking up a line or two, not taking enough into account. So Chris, what would you suggest for controlling the egt's a little more? I would like to make it like others where they can keep it to 1200 for the most part. Maybe the other thing is to have the truck downshift a little sooner to 4th due to the bigger tires instead of having to do it manually.
To change this downshift, I assume this is all in the TCM right?
