While towing this weekend truck went into "reduced power mode" 6 times. Always happend in the middle of a grade or on the descent when you get back into throttle. I talked with company I got efi from and they said its going into fail safe mode because of excessive boost. They told me they could shut off the fail safe mode off but I would run the turbo out of its map. If I have them shut off fail safe and install boost guage and pay attention to it on the hills? How much can this stock turbo take? I understand that it's just making heat anything over 30psi. How much boost will the hg handle? Anyone else run into this issue with there LML while towing? Thanks Scott
