Torsion key tool?
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
#1 does anyone know where to find on cheap? i need to get these drop keys in
#2 is there another tool i can use or something to nig rig it?
#3 anyone know where to find a god write up on how to change the keys step by step?
thanks guys,
Beech
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Take the wieght off the front tires and use a 2 jaw gear puller if needed
once the bolt is loosened off you might need to beat the bar towards the rear of the truck once it is out of the front then just pull the bar out and remove the key
Redbowties88
Aug 24, 2009
1,943
609 New Jersey
:confused:
2 jaw gear puller....guessing i can get one at my local auto shop? sorry im no mechanic. theres already no bolts in the keys they're removed for full drop. so that bar just moves backwards? sorry for my ignorance
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
beech, yes all you need is the 2 jaw puller. make sure you use an impact to tighten it though so it doesn't twist. make sure the point of the puller is in teh divit of the key
once you do that slide that nut piece out of the slot and loosen the puller. then just slide the bar foward and the key "should" fall out
call me if you need anything dude:thumb:
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
:confused:
well ive had to beat on them sometimes to remove them...Now mine come out real easy.
once you take the wieght off its removes all the tension on the bar
when you jack up the front watch for play on the key:)
You probably wont find a 2 jaw but you can get a cheap 3 jaw and just remove the one jaw or use a c-clamp but just be very carefull if you do this with tension on the bars
KEVINL
1,431
Phoenix, AZ
undo the UCA ball joint and drop down the jack and let the LCA drop out there will be hardly any tension on the bars then
I used a extension on a jack and put a little pressure to slide out the block and let the key drop down
custom8726
2,784
Upstate N.Y
When I put my lift on, I did not have the correct tool or did I know I needed one at the time. I used a steel pipe wrench (18" or so) and a jack. Simply lock the pipe wrench on the torsion bar in a position were you can lock the jack head on the pipe wrench handle. Jack it up a little to release the tension and remove the key. Not the safest route to take but with a little common sense it can be done fairly safely IMHO..
P.S. while the truck is all ready on jack stands, of course;)
1,866
Beech, I have one...if you want to borrow it, PM me your address. Its already in a box, ready to go.
If you use a gear puller like Sweet and Low say (hey...thats funny in itself), I will come to your house and slap the crap out of you. :rofl:
Just ship it back to me when you're done.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Tom I understand the results of using a improper tool bur once weight is removed I don't see a issue, it's no diffeent than being at the track and lowering the bars IMO
Sweet and low out:D
jheyob
305
Okeana OH/West Lafayette IN
If your bars are froze in the LCA and keys like mine were, an air chisel helps! I used a 2 jaw puller for my leveling key install...$35 at napa, tons of uses, buy one.
EDIT: the bar also moves forward through the LCA not backwards like you thought redbowties
13,713
775
There is actually still a lot of tension on the bars when the tires are off the ground.
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
X2
1,866
Sweet and low out:D
ok, whatever....its not the same as lowering bars at the track (the retainer bar is still there, just the bolt moves...)
Beech, Ben...the offer stands. You both can borrow my Tbar clamp if you want to. Cost you all of $10 shipping at the most.
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Tom I am not dissagreeing with you I would always prefer to use the proper tool . If you offer the tool to another member that great:) The op asked for a ghetto rig and that is what I was offering
Abby spends alot of time on jackstands sadly I was underneath. one time and grabbed the torsion bar to pull myself up on my creeper. The bar pulled out of the front and landed on me:rofl:
