Well I'm looking for new torsion bars. My driver sided is sagged out and the sticker with the code on it is no longer there on either one. I did some looking online and found multiple part numbers depending on were I was looking. Can anyone point me in the right direction on which of these part numbers would be right for my truck or let me know were I could find a more info on how to find the right ones.
Below is some post from another thread.
There should be a paper tag on the bar with a two letter code. Here's a list of the codes and associated part numbers with their torque (weight) rating.
CHEVY TORSION BAR CODES AND RATINGS:
15048307-LH (code XK) (Max torque 4553)
15048308-RH (code XK) (Max torque 4553)
15048309-LH (code XL) (Max torque 4626)
15048310-RH (code XL) (Max torque 4626)
15712407-LH (code WX) (Max torque 4863)
15712408-RH (code WX) (Max torque 4863)
15048311-LH (code XM) (Max torque 5638)
15048312-RH (code XM) (Max torque 5638)
15528955-LH (code GF) (Max torque 5826)
15528956-RH (code GF) (Max torque 5826)
15058267-LH (code YH) (Max torque 5913)
15058268-RH (code YH) (Max torque 5913)
15712409-LH (code WY) (Max torque 5913)
15712410-RH (code WY) (Max torque 5913)
15528957-LH (code GG) (Max torque 6707)
15528958-RH (code GG) (Max torque 6707)
15528959-LH (code GH) (Max torque 7161)
15528960-RH (code GH) (Max torque 7161)
15712411-LH (code WZ) (Max torque 7267)
15712412-RH (code WZ) (Max torque 7267)
15528963-LH (code GK) (Max torque 8615)
15528964-RH (code GK) (Max torque 8615)
15528965-LH (code GL) (Max torque 8782)
15528966-RH (code GL) (Max torque 8782)
15732338-LH (code XG) (Max torque 9054)
15732339-RH (code XG) (Max torque 9054)
Well I think i found my answer, if you click on other suspension parts in gm parts direct i can see the 1Ton torsion bar for the 3500 which is this guy
So i guess i definately bought the wrong torsion bar!
Manufacturer: GM
Part Number: 19330060
Part: TORSION BAR, LEFT
Part Notes: 4WD, 1 TON
