I've had my green keys for about 6 months. I want to lower the front about 1/2 inch. If I jack it up and loosen up on the torsion bars will I need to have the front end re-aligned?
too lower the torsion bars you don't have to jack the truck up, only when raising the truck up again. and yes you will need an alignment once you drop them.
With in 2-4 turns you should be ok if more then tht then you will def need alighnmnet
Changing the ride height will alter toe in drastically. It will definitely wearout your tires.
