Just measured from the block to the flywheel and i get a hair over 24mm. Measured from the bell housing to the converter and i get a hair over 28mm. Would that be fully seated?
You draw the converter forward towards the engine with a screw driver. It better move forward. Never draw a converter forward by tightening bolts as it is a sure way to disaster. After you draw the converter forward with the screwdriver, you must be able to spin the converter freely.
Are you sure you installed the bellhousing gaskets correctly and on the correct sides of the separator plate?
Sent from my SCH-I535 using Tapatalk 2
