This could be true if all extensions were the same, but they are not. Tire shops have special extensions to tq wheels.
but the way an impact wrench works though is much different than the way a torque wrench works as far as how the bolt sees the force applied, when you use a torque wrench its obviously a constant smooth force, where as the impact wrench hits it with little bangs.
Because an impact "hits" so fast, the force is absorbed by the twisting of the extension and the torque doesnt have enough time to transition smoothly to the bolt head. When an impact wrench "hits", its always hitting with the same force each time. When you put leverage on a bolt/tighten a bolt with a torque wrench or ratchet, you are constantly increasing the force exerted on the extension/bolt. I guess when an impact wrench says its capable of "500 ft lbs", all that means is it hits the bolt with enough force to get it tightened to the rough "equivilant" of if you ACTUALLY applied 500 ft lbs of smooth steady static (not dynamic) force to the bolt with a breaker bar/torque wrench.
Thats why the torque sticks work; they are only compatible/work when used with impact wrenches because of the way an impact wrench exerts force as a moment arm. If you apply a smooth constant force to a torque stick, its not going to work properly. Say you have 2 bolts and a single torque wrench set to 100 ft lbs. One of the bolts you tighten directly with the torque wrench....pull the wrench until it clicks. Then put say a "50 ft lbs" torque stick on (but kept the torque wrench set on 100 ft lbs), and repeat until the wrench clicks. If you then measured each bolt I guarantee both would be roughly the same torque. HOWEVER, if you use an impact wrench in that situation, all bets are off and they will NOT be torqued equally.
Thats why it is especially important when you use a torque wrench to tighten in a smooth steady pull...dont bounce on the torque wrench because
in that case if you are bouncing on the torque wrench to get it to click, yes, twist in the extensions WILL affect it.
I cant really explain it though??
ben
EDIT: foster beat me to it...nvmind
