toasted the lift pump, what to get?
95geo
Junior Member
Aug 8, 2006
13
20 micron with water seperator.
fleetguard fs1212 (i lied, its only 8" tall..... its funny how our memory works like that some times:rofl:)
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
like a fishing story:D
where did you put this filter the frame rail?
luckily i get the raycors from work:secret:
95geo
Junior Member
Aug 8, 2006
13
I got the parts from napa and a few connectors from work. I didnt cut anything factory and I can bypass it with one straight screw driver.
I get these filters, uhhhhhh..... cheap too!
when my source runs out I will probably get some better ones.
WildChild
May 31, 2007
17
NORTHERN IOWA
They will flow enough to get ya home, but if you drive it hard it will limp. I had a check valve bypass plumbed in and I got home with no problem. I was about 100miles from home running a bigger tune than I should have been pulling a 30ft Haulmark and my Chevelle:D
Shouldn't have stranded you they are flow though. Pat drives around with his off in Casper.
