Only thing I can think of is the lash must have been adjusted wrong
2004LB7 Super Moderator Staff member Dec 15, 2010 7,267 2,307 113 Norcal Aug 29, 2023 #21 Only thing I can think of is the lash must have been adjusted wrong
1FastBrick Well-known member Dec 1, 2016 2,707 1,191 113 Junkyard Aug 30, 2023 #22 I would say, Oiling issue and or a miss adjustment of the valve lash. I wonder if the ports in the rocker rails are plugged up.
lexa Member Oct 28, 2012 32 0 6 Moscow Today at 4:00 AM #23 Hi! Mine lb7 has the same sound from intake when cold. How can I determine which side of the engine should be disassembled ?
2004LB7 Super Moderator Staff member Dec 15, 2010 7,267 2,307 113 Norcal Today at 10:03 AM #24 lexa said: Hi! Mine lb7 has the same sound from intake when cold. How can I determine which side of the engine should be disassembled ? Click to expand... Kinda a flip of the coin. You might be able to run the engine with the y bridge removed to see what side. But would be prudent to inspect both anyways
