I can strap my old small quad in ok around the stack.
As far as the rain/water problem...When I had a miter it was horrible, I would somehow get soot all over the dash, that should give you an idea of how the roof looked
i know i'm a little late on this thread, but i just wanted to throw in some info from my experience. I've messed around a lot with stack styles and the heights of the stacks. I have found the key to "noise" is height. If the stack is as high as the roof (like mine) you won't hear to much from it on those long highway drives. Don't notice much drone at all really. Now if you have the stack half way or three quarters the way up the rear window, you'll def hear it more. Like i said, i know this is really late, but maybe it will help
Great pics custom, Ive been toying with the idea of running a single 4 inch, kinda wanna stick with stock exhaust size thru out the stack, but little wondering about running no muffler. I have the LB7 duramax. and takes on how loud it would be? also if I wanted to run a muffler (dont really want to) but if I needed to, anyone know how hard it would be to do so.
Correct me if im wrong, but if I drop the cat I would throw eng codes right?Easy, just put a muffler back on underneath were you have the cat delete pipe. Or if for some reason you still have the cat they make muffler drop in's for the stacks....
Correct me if im wrong, but if I drop the cat I would throw eng codes right?![]()
