This sucks!
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
Made it about 3 miles from house this morning. when I got to stop sign, truck was shakin'. Went about another 1/8 mile to pull into a parking lot and she's a knockin/poppin'! I pulled dipstick out and smoke's commin' from tube, pcv vent, and oil fill. Noise more audible from drivers side. Well, that was a expensive 12k miles. Depending on what it is, this might be it for the diesel world for me.:mad:
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
Wow that is terrible. YOu just rebuilt your motor not long ago either correct? When are you going to tear into it and diagnose?
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
All my real tools are at the shop. I'll have to take wife's car tomorrow to get some. I guess I'll do a compression test first and pull valve covers. I hate to have to do this in a dirt driveway. And yes, finally got in running 1 year ago almost exactly.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Buddy of mine had his knocking like crazy and it was a stuck injector only stuck open.You would swear it had a rod knocking he let it go thru a few heat up cool down cycles and then he got pissed and kept reving it and it just unstuck.You can also do a cranck test after you pull the injector fuses and you have taken all the glow plugs out if you crank it feul will only come out if the injector is stuck open. hope this helps and good luck.
01LB7
Feb 18, 2010
206
Missouri
mine did the same thing, I thought I was f'ed in the a, 2 injectors later, purrs like a kitten, good luck hopefully it's not too bad for you
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Are you loosing any coolant?It could be remotly possible but you would have to have a cooper and an o ring fail at the same time.When i pulled my injectors almost every 1 the oring was sliced And that was from a dealer, but the coopers where holding i think.Have you been able to do a compression test yet?Anything in the oil?
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
I didn't have way to get tools today. But...... I just went to move it out of the way and- Coolant still has pressure after 26hrs, Knockin a hell of alot louder, and smokes pouring out pcv vent. Should I bother poking? or just pull?
Colt
Jul 23, 2010
523
wouldn't run it until comp. test is done. Just have to do one thing at a time, driving it seems like it would just damage more. Guess it's like the less you run it right now the less might get hurt to a point.
