thinking about bigger turbo
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
I vote for a PPE/Garrett GTX4202R!:D but a 40/94R will make 650 no problem.
let me know if you are interested in any of our parts.
dmax711
Mar 4, 2011
1,057
concord, north carolina
I have trents s464 setup and i tows just fine, plenty of power and like trent said its a great stepping stone. you can upgrade the charger with just a wheel and cover swap if you decide to go bigger, or twin off of it.
dmax711
Mar 4, 2011
1,057
Its nite and day compared to the stocker, honestly i was tossing around the same idea as you and a buddy of mine had a s464 kicken around so i bought an install kit from trent, and now im already looking to upgrade to a larger turbo. Im glad i went the route i did and can do almost anything i want off of my current setup without changing much.. call trent hes a good dude and will take time to explain to you different options, i bug him probally every other week and he always answers my questions..:thumb:
Tank222
Feb 17, 2010
337
Frederick,MD
Thinking about ditching my 68mm cheetah and buying a s475 setup from a member here. I tow a boat in the summer, loaded it's around 8k. Probably will never tow any thing heavier. Running a Precision ML converter that's pretty loose. Just looking for some idea's if it would be a wise move.
6,081
your big tires dont help you. at 8k on the back, your gunna have to really raise shift points and kick down points to keep on top of that charger. you will really have to "drive the truck"
Tank222
Feb 17, 2010
337
Frederick,MD
The only reason I'm considering it is because he's got everything in a kit for $2300 and I figured I could almost get that out of my cheetah, rld y bridge with egr delete pipe, and afe driver side piping.
6,081
if you want it to work bad enough, you can make it work ;).
HDdave
173
Wilmington, NC
Was dragging my boat around the other day with my s472 with no issues what so ever. Granted its a slight bit lighter, and you have bigger tires. But I had no complaints. It drove perfectly normal, egt's barely got over 1100.. Only spot is if you hit a hill doing 55 with the converter locked, your going to have to bump it down one, because it gonna lug pretty bad there. My old charger I could usually keep the tranny locked up and just power up the hill. No harder to make it drop a gear then your smooth sailing.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I tow 5-8k weekly on a billet s475. Raised shiftpoints and a slightly different driving style and it does fine. Unload when it lights its NASTY!!!
Tank222
Feb 17, 2010
337
Frederick,MD
My truck now at 75-80mph is right around 900 egt's. Not sure if it's sold yet, I haven't gotten a response back.
HDdave
173
Wilmington, NC
Oh yeah mine stay nice and low as well. I crested over 1100 at 55mph when I was merging slowly onto the highway. With the converter locked its dumping a lot of fuel but the extra weight is holding it back. I could not be happier with how mine drives and tows. I was seeing temps near 1500 with the stocker in normal driving situations.
