What the hell!
I haven't driven my truck for awhile,quite awhile.
Basically it's driven inside my shop more than anywhere moving it out of the way. So I move it from one side of the shop to the other ,park it ,get out and there is a trail of motor oil from where it was to where it's parked! WTF
So I get out the creeper and flash light fire it up and crawl under. Oil is running out of the Oil Pressure Switch! I mean it's raining! I'm sure it's that as the guage is showing about 8 psi.
So if anyone knows the part number (GM) please pass it along and if you need the special tool to remove. If so if you know the size pass that along also. I don't believe a standard deep socket will do the trick so a sender socket might be in order.
Ah tank-a-you very much.
