The custom "ben" intake bridge
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Ok so we all know how stupid the intake bridge/elbow design is on the LLY+ engines. So I figured I would change it for the better when I put my new engine in.
The issue is that the elbow is not attached to the bridge in any way shape or form. It relies on the EGR motor housing (or a custom bracket) to keep it from blowing out of the bridge. The o-rings alone seal it from boost, but dont prevent it from being blown out under high boost.
I just left the EGR motor housing in place previously (took out the EGR cooler though), but I decided to make it cleaner this time around. Also, that flange where the elbow attaches to the intake manifold is a weak spot and always prone to leaks. If you have twins, this area gets stressed even more because as the motor moves around under the torque, it loosens up the flange and elbow.
My solution fixes all of these problems, and provides more give in the post-CAC intake piping system.
I thought about just welding the elbow into the bridge, but if you have to replace the CP3 or anything, it makes it a MUCH bigger job. It makes things a LOT easier if the elbow remains removable.
First I ground off the flange on the elbow, but left a bead to allow a silicone boot to seal without getting blown off. Then I drilled and tapped the intake bridge and elbow to allow two stainless steel screws to be screwed through the elbow and bridge itself. This holds the elbow in place, and keeps it from being blown out under boost, but also allows the elbow to be easily removable for service. When I put the screws in, I had to drill it more near the edge than I would have liked to, but also had to avoid drilling through where the o-rings seat. I also put some thread sealer on the screw threads to seal that up. So far zero boost leaks.
Then on the intake pipe for the twins, I did the same thing. Cut off the flange, and welded a bead around to allow the boot to seal. I upgraded to the LBZ intake manifolds and bridge/elbow at this time as well, so the boot I used needed to be a 2.75" to 2.50" reducer. (the LBZ elbow OD is 2.75", the LLY twins intake pipe is 2.50" OD) I also had to remount the MAP sensor because the LBZ intake manifold does not have the mount/hole for the LLY MAP sensor.
Anyway, just thought I would share. Big thanks to Tacojedbob, he did the MAP sensor relocation bracket, and Madisonjam85 did the drilling/tapping/grinding (I was busy putting the heads and stuff on the motor).
ben
slowlmm
Mar 2, 2008
2,582
46
so cal
Thats pretty sweet ben. As I pulled that off this morning at like 2am I was like hmmmm just press fit in? Seems like it could just pop off.
Looks good ben.
mat I dont ever see that thing being able to pop out its in there very tight and kind of locks in as well.
slowlmm
Mar 2, 2008
2,582
46
so cal
you would be surprised tommy. It will pop out easy as pie above 25psi or so.
ben
Oh really? mabey thats where some of my boost was going when i had my 40-94 hmmm i actually used gm selant when i put mine back in becuase one of my orings had a nic in it. mabey i should look into your solution there.:)
Cougar281
1,834
276
St Louis, MO
Neat mod, Ben. Is that a LBZ bridge? I thought the elbow was held in with a small bolt or something since I couldn't get it out when I was trying to a while back... Guess I was wrong.
Good to hear your truck is back together (or almost back together). :thumb:
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Dave- yes thats an LBZ/LMM bridge
The LBZ/LMM ones do seem to be a tighter fit than the LLY's for some reason. But they can still pop out under higher boost.
jckleewein
Dec 13, 2008
422
Broomfield, Colorado
I don't like the elbow design. I broke mine somehow when I was installing the turbo. The elbow came out pretty easy once I got all the other stuff out of the way. I was going to buy a new elbow, but found a used one. The gaskets and elbow are not cheap.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Doesn't take too much to pop them apart with your hands either. Pulled an lmm elbow with minor wriggling. Easy to see how excessive boost could force it out. Nice idea/writeup.:thumb:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Thanks for the writeup!
Take the area of the neck, and multiply by your boost. 400lb of force? (guestimate) at high boost. Casper bent a steel bracket that held it in when we were racing in Las Vegas and developed a boost leak. Your fix looks stronger.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Well that was short lived. It blew out today/ripped the aluminum. I had to drill the holes close to the edge to avoid hitting the o-ring. They tore today under all of 25psi boost (im running a stock tune)
So back to the drawing board; I might just tack weld it in place. (tack weld the elbow to the bridge)
If I make the elbow piece non-removable is that going to be a huge problem??? IE, is it impossible to unbolt the manifold bridge with the elbow in place, etc..??
ripmf666
15,123
14
47
Wentzville Mo
I would mark were you need it and tig it in place.
