I think the cp3-4 is the big one. I've been trying to get a part # but no one want's to share or just doesn't know? I'm not sure if the stroker pumps out perform it or not.
Industrial Injection has a 92% over flowed pump for the dodge, But dont know if they do a Duramax pump or not. You could check with them.
they make a 240% for the dodge which would be a nice setup for a duramax
I tested the II pump vs the Wicked Diesel pump, and the WD pump flows alot more, especially at higher RPM's.
I have 2 Industrial Injection pumps for sale right now that have very low hours on them. I upgraded to the WD pumps.
Where would you mount this monster if you wanted to go with a big single? Not much room if you want to do a set of twin turbo's as well.
If Im not mistaken the "grand poo-bah" is also a CP3.4??? If i remember right, I think i remember hearing the 3.4 is just big enough to not fit where the stocker is....so that IMO oughta be fine in the typical dual fueler spot by the A/C compressor??? Need to run oil feed and return off of it anyhow. I didn't know they werent avalible here explains my difficulty trying to find out about the CP3.4, i thought they were installed on the Duramax I-6 cylinder engines on the big Isuzu cab-over trucks? Anyone have a price on these for curiosity sake
right where the twin cp3 goes
And then build a flange to cover the hole in the valley?
