Take a look at these videos and let me know what you think may be a place to start. I know how to diagnose a truck, but I'm obviously not a professional nor do i have the time to spend a day on it until the weekend. But I need this truck to be reliable and this past week has made me second guess it.
This started last week, happened once, until yesterday and today where the occurrence re-appeared. This has only happened under these conditions
Hot weather
Driven over an hour in the morning
Let it sit all day tunil about 4:30 (solid 8 hours outside in the sun)
Go to leave work and the truck starts to bleed from the womb.
What the hell is wrong with this idiot truck of mine? I dont mind busting out the V2 and logging, Figured I would call upon the crew and pick some brains better than mine.
The vane position if you can see in one video is at 85%, something throws me off because they're clearly wide open from the sounds of things, it chugs, huffs whiteish/grayish smoke. Desired and actual rail are even with each other at the time.
Its apparent I need more data than noises, and captain obvious stating the well, you know.... Truck has 200k on it, just replace the injectors with Bosch from LDS. CP3 is original and holds 24.5k rail on 2750us WOT. LBZ reg, but I still feel like this is a problem area. Odd part is, not a minute after this crap happens, the truck runs perfectly fine. fuels, and pulls hard. Until tomorrow when I go through this cycle again. :roflmao:
https://www.youtube.com/watch?v=Jvbobf7scGg&feature=youtu.be
https://www.youtube.com/watch?v=f5F6wqx59A4&feature=youtu.be
Hot weather
