Texas events can...
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Killing the engine while racing would probably be more hazardous than letting it go crazy. Our brakes and steering are controlled by the engine, and if the converter remains locked it will "upset" the vehicle, shifting the weight forward, which can be a handful if you have soft racing tires on the back.
Runaway diesels are problem regardless of whether you are racing or not. The CO2 extinguishers that are at most tracks will kill the engine regardless.
Another factor to consider is that many of these guys are using nitrous. A airshutoff will not stop the engine if the air is coming from a bottle. Nitrous solenoid sticks, turbo blows as a side effect, and you have a runaway until the bottle is empty. Except a normal runaway is "low power" because normally the boost is gone when the turbo shaft breaks, a nitrous runaway is a "boosted" runaway.
turbo-max
WaaaZaaaa
Aug 9, 2006
1,037
56
Tampa, FloriDUH
if someone is racing and has a run-away,and can't controll it,they deserve to crash...non driving basterds...
*this is my thoughts only,and does not imply the thoughts of anyone else unless they too agree.*
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
We still don't have everything we need to comply with DHRA ProStreet rules.
#1 is a truck!!! :D Took a bit longer to get a rollbar than we anticipated.
#2 is a trans blanket. Hasn't arrivedd.
#3 is a air shutoff. Hasn't arrived.
Seems I started all of this way too late. :(
RyanZ06
Oct 6, 2006
46
I am looking forward to seeing you guys in houston... I hope you get it together in time.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
We won't be making Houston :( Parts didn't arrive and Pat has a hot job at the shop that only he can do.
Sucks sometimes being self-employed.
RyanZ06
Oct 6, 2006
46
Anyone know where I can get a SC IV done before the weekend in texas? :D I want to run at the drag races, but my stock tranny will self destruct :(
