LB7: Teardown thread
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Well I fought with the valve cover for two more hours and ended up breaking the valve cover on accident.
So does anybody have a spare driver side lower valve cover for a lb7 they want to sell.
Here are some pictures of the sleeves on the driver side.
Sorry for the crappy pics my camera battery went dead but it looks like I for sure have a blown headgaket
Guy at SoCal should have some.
ripmf666
15,123
14
47
Wentzville Mo
Just make sure you don't brush the tips. I'm sure you know this though.
  1. Notice: The fuel injector must be cleaned with the proper cleaning equipment. DO NOT use abrasive cleaning methods, such as a metallic brush, to remove deposits. Cleaning an injector with improper tools will damage the fuel injector.<LI type=1>Use a soft bristle non-metallic brush and top engine cleaner, GM P/N 1052626 or equivalent, to remove any deposits from the nozzle tip (1) and the copper washer sealing area (2) before re-installation. <LI type=1>Inspect the fuel injector nozzle tip (1) for any signs of discoloration (dark yellow, tan, or blue) due to excessive heat.
  2. Replace the injector if any damage is found.
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
isnt that what I said:confused:
KEVINL
1,431
Phoenix, AZ
Well I definetaly had a blown head gasket
Here are some pics
Oddly those cylinders had the highest compression numbers
KEVINL
1,431
Phoenix, AZ
I am trying to figure out the valve train,
I made the mistake of not seeing the orientation of the valve bridges although I have them set where they look like they are all in full contact with the rockers.
I also didn't mark which side was which of the valve train assembly.
I havent torqued it downcompletly but some pushrods have alot of play.
AnY info this
I don't want to have to adjust the valves
ripmf666
15,123
14
47
Wentzville Mo
You have to back the rockers off before tqing the shaft mount down,and you must reset the valave lash, You can break the rocker shaft trying to bolt it down with out backing the rocks off o even a push rod.
KEVINL
1,431
Phoenix, AZ
Nothing can be easy
Do you have the valve lash adjustment procedure
I also need torque specs for injector holddowns
KEVINL
1,431
Phoenix, AZ
So it looks like I only have to set the crankshaft at number 1 TDC on the intake stroke adjust the highlighted valves
then number 1 tdc on the exhaust stroke. and adjust the remaining valves
And the intake and exhaust valves use the same lash .012 inches or .3mm
How do I know when it is on the intake and exhaust stroke?
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
watch the valves and wait to see the intake arm open up and close, having the number 1 injector out helps
