Allison 6sp: TCM Dyno tune
1chevy02
Jun 23, 2009
504
I'm gonna try the same thing on the dyno next time. I don't know to much about trans tunes but it look to me like you need to raise table D5028 also to prevent the 4-5 upshift
1chevy02
Jun 23, 2009
504
ok sorry i guess i misunderstood i had problems with mine still upshifting. what about holding it in gear with the dvt on the scantool
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Ive thought of that but I figured this would be easier. If you noticed the trans operates normally in O/D. turning on tow haul should make the truck go into 4 at about 15 and stay there. Should be easy just tell the dyno operator to hit t/h and he wont have to worry about it shifting
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
From what i understood is that on the 6 speeds you can only stop it from up shifting not down shifting. I think you'll have to find a good rpm starting point and roll into the throttle just hard enough to keep it from down shifting during a dyno run.
13,744
817
Are you leaving it in D or pulling it down into M? If you put it in manual mode, the TCM shift point changes will not work. If that isn't your problem, try changing all except Pattern A. I had a problem with an LB7 doing the same thing.
13,744
817
I did it on mine.
edit: I just went and looked at my tune. I have it set to hold 5th in normal mode, and shift through all the gears like normal in T/H mode.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I'll try pasting into those patterns too. I just rememberd that my truck pops out of gear when using the DVT to lock it so I hope this will keep it from downshifting. Could be my only way to lock it in gear
GTA23109a
<-- Prius owners love me
May 9, 2007
97
Bakersfield, CA
I've been thinking about this same thing for a while. I threw what I *think* should be a 4th-gear-hold dyno TCM tune. If somebody wants to take a look at this and see if I'm even on the right track, that'd be great.
  • LBZ_TCM 4th gear dyno.tun
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
sorry to bump this thread up but will the above tune work for a 4th gear dyno hold?
Don't know why would you need it, just drop the shifter into M-mode and click to 4th, works in regular and T/H mode on the 2006-2010 trucks. And honestly, I would NOT use a tune that was not read out of my trucks TCM...
N2BRK
2,069
400
I didn't look at the tune, but I have to disagree, Mike. My truck kept downshifting when Mark was trying to work on the bottom part of my tune while on the dyno. It would have been a big help to have a tune that forced it to stay in 4th.
