T-case failure
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Think I finally broke something. 4x4 let go last night doing boosted launches. No problems until I the last run, went to launch and realized 4x4 wasn't engaged. Never any noise or pop, just no power transfer. Jacked it up today, actuator is working fine, low range engages just never locks the front driveshaft. I'm leaning towards the front output being broke but I don't feel any play. All guesses right now, ill know this week hopefully!
On the bright side, 13psi launches like a dream with the lowered stance. Very smooth out of the hole. Probably did 7-8 launches
08 LMM Duramax
Relentless Diesel trans
JoshH custom tuning
554hp 1014ft-lbs 7/30/2011
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Not yet. I will try to do that this afternoon to troubleshoot a little further before it gets torn down
08 LMM Duramax
JoshH custom tuning
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I manually actuated it, something definitely let go. No grinding of any sort, just no power to the front driveshaft.
08 LMM Duramax
JoshH custom tuning
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I may have an output shaft ill have to check not sure if you want a used or not
I may have it taken care of but if not, how much you want for that used one?
08 LMM Duramax
JoshH custom tuning
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
prorlly not much let me see if its ok the t case i down at my buddies trans shop taken apart the 1 bering and the tail housing are no good and i stoped there i have another spare and didnt feel like putting the money into this 1,ill check tomorrow and let you know
