If this says anything, I wish i would have spent the money on my engine. Now to put rods in it will cost me the almost as much as the rods themself, by the time you figure up all the little costs you don't think of.
ive always wanted to see someone throw just a set of LBZ rods or carrillos or something like that in without doing anything else (maybe delipped pistons). i just couldnt see the motor lasting as long as it could doing that.
you can certainly do it. the issues you may see is a bit more blow by or oil consumption due to reusing rings as they will no longer be in the same place they were prior in the cyl (this is what ive been told, im 50/50 whether its true), your crank wont like you as there is more rotating weight on a unbalanced setup as the stock stuff was not balanced to begin with, and you will still be on stock pistons and while they are strong, you still have the weak point of the lip left and from what ive seen, its a crap shoot on if they last above 650-700hp or not.
Chris, if I were to do it again, I wouldn't bother. Wait, save up, and at least put some Manleys in it.
Break out the grinder and shave some grams off
Trent Nell (carrillos)
Me (LBZ rods) maybe others? 40,000 miles on it with no issues, and when it went down the track, it was making more power than before the rebuild.
5300 lbs trapping 108mph is roughly only 455 horse...you have plenty of room to grow on that stock bottom end. I would not be worried one bit to do 11.50's on the stock bottom end.
I have countless passes trapping 113mph at 7000lbs race weight.
A turbo and a small set of nozzles will get you there no problem.
