Swapping on bigger nozzles
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Has anyone just swapped on bigger nozzles without having them balance afterwards? I know the correct way is to have the injectors balance after installing new nozzles, but trying to do a budget build and my injectors are in good condition. Looking to go up to 100-150% over size on a LBZ. Thanks for any input!
N2BRK
2,052
371
you're well beyond the size that I did, but I can tell you that I did 40 over LBZ nozzles on my LMM bodies, and just swapped them right over after Extrude Hone opened them up. No issues - 3yrs + so far.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Yeah, I remember when 100's were crazy big! :roflmao:
I really only need enough fuel for 800hp, but would be nice to keep pulse width down and have room to grow in the future if need be.
N2BRK
2,052
371
only 800, leave em stock... let's see how high that PW table will go :) Reminds me of a thread back in like 08/09 with how much power can you get on stock sticks :)
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
Plenty of people have done it. Doesn't mean it's necessarily the best idea but it might not be the end of the world either.
If the nozzles are flowed and made the same there probably isn’t much issue. But if some are 95% and others 110% might not be good. I sent a set off to a company and had them done 60% over for $200 they were all within 10% and balance rates are great. That truck was built for 650hp.
20dmax08
57
That’s pretty cheap. $200 per nozzle?
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
All 8. IIRC that was the biggest they would go, anything bigger you would send all 8 injectors and they would flow match them for $1000.
Edit. It was $280 to have the nozzles done.
ikeG
Oughta Know Better
Apr 19, 2011
2,462
146
Western PA
www.facebook.com
I have used 4 different sets of nozzles from extrude hone without any problems. From 40% all the way up to 180%. From 600rwhp to 1200ish. They all were swapped without balancing onto extremely healthy injectors that I had owned and controlled since day 1 though.
9,903
149
I wouldn’t do extrude hone unless the injectors were almost new with even rates. Mine weren’t and they didn’t work out that well for me.
N2BRK
2,052
371
Mine were old used second hand tips and I went extrude hone 40 over - they’ve been great for years. Just had another set done and need to still install them.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I had a set of very low mile exergy 100 overs. Took a chance and went to 200 over nozzles and it didn't work out in my favor. Now I'm stuck with another bill to get them fixed. I would suggest having them done the right way. I took a chance and it bit me.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Good to know...
IdahoRob
Jun 5, 2007
1,151
We used to hone tips all the time before the craze of running monster injectors. 30%-40% tips done by extrude honing and they always worked great. $200.00-300.00 and never had or heard of any problems.
As stated, most honing companies will not go over 60% so i didn't have any experience with just tips of the larger than that.
Some on the forums started saying that the only way to run bigger injectors was to spend big dollars or your engine would blow up. Then this view caught on, and became the norm. I say B.S. to that view based on my personal experiences with the smaller sizes.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Yeah, I've always just bought complete oversized injectors, but was trying to do a budget build on this one. I had one injector go bad on my pull truck and just bought one new LB7 injector from GM and swapped the 150% nozzle on and balance rates came right back in and never had any issues. Dang, I'm really on the fence with what to do now...,
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I’ve swapped 100%. Nozzles on a couple budget trucks with zero issue. I wounding be scared of it if I have a good set to start with
