I have a BDS Suspension on my Avalanche 2500 that im putting back to stock and replacing with a 04 2500 DMax. BDS says the kits are the same for both trucks so I want to swap the stock suspension of the Silverado onto the AV and vice versa, anyone see any issues?
Only thing I was thinking was the differential swap might not work, I had to lob the top off of the AV diff for the lift to work and im not sure if the diesel diff is the same as the Avalanche, anyone know for sure? I could use the diff fix from Cognito obviously but if I can just swap it all between trucks it would be easier. Ill give BDS a shout in the am just figured id throw it up on here see if anyone had any insight
