hahaha
I was just re-assuring you that BLKLMM was indeed a very experienced racer, nothing more
the toe setting thing is a crucial element cuz as the truck launches and the front end lifts, the front tires "toe" in, or point in to the center. if you lower the t-bars the toe setting will actually start to point out the lower you go, and this is helpful for when the truck launches cuz as the front lifts the tires won't toe in and create friction drag or bind. If you lower the t-bars and have an alignment done, the benefit of having the toe setting pointing slightly out will be lost and even though the t-bars might be down you'll still get the dreaded IFS pigeon toe or "toe in" at the launch and while traveling down the track under throttle
removing the T-bar bolts completely will get you the lowest and some guys even cut the jounce bumps on the LCA to get even lower, the lower you go the less lift/weight transfer you get to the rear and you'll receive better contact/traction to the front tires with less chance of wheel hop.
it was mentioned that you can also run the rear leaf pack clamped, but I always thought that was a sled puller thing:dontknow:
looks like that was a pretty clean run, nice:thumb:
I'd start with some QA1 double adjustable rear shocks and a set of cal tracs, maybe down the road get a set of slicks or depending on what the daily duties of the truck are just run some cheater slicks and see what that will accomplish.
you still running the emissions crap? cuz I noticed a pretty nice increase of throttle response from a complete EGR delete with the 3" IC cold side tube, that could help your overall ET not sure if it'd help the 60' time all that much
