Surfaced heads
Lookingformychevy
Nov 30, 2015
17
Took heads to a machine shop and had surfaced and valves grind they can't tell me how much they took off or how deep they set the valves how can I go about checking this before I put the heads on don't want valves to hit piston.
Awenta
4,090
Is that a joke? Have they ever done a head?
Lookingformychevy
Nov 30, 2015
17
No so now I am either Goin to need another set of heads or someone tell me how to check
Awenta
4,090
C gaskets and playdough. You should be fine but use a different machine shop next time
5,818
I suggest you take them to another machine shop and have them check to see if the decking was done level and if the valves were done correctly. The fact they can't even give you a number on the amount they took off tells me that you should trust nothing about the work done to the heads.
andy-stevenson
Jul 7, 2013
838
They'd be paying for a new set of heads if they were mine. If they can't tell you how much they took off the surface or valves who knows what else the f'ed up. They'd either be buying a new set or sending them to someone who knows what they're doing to check everything over on their dime.
Lookingformychevy
Nov 30, 2015
17
That's what I'm doing tomorrow taking to another shop and let them check and see what they did
