Stupidest thing ive done in a long time, need opinions.
ACiFiC
Oct 14, 2012
119
Canada
Alright so I got an AUX fuel tank from my dad (gravity fed) and i went to go plumb it into the vent line on the filler neck.
it was one of those vacuum lines, which was weird...thought it was a little small.
anyways fastforward >> fuel wasnt going in the tank, couldnt figure out why blah blah blah. ended up cutting the vent line and going closer thinking i went to far and still didnt work.
i usually work for 14 days in a row driving 45 miles a day everyday.
so on my last day where i was driving home. i hear howling and grinding and whatever else. thought my tcase or front diff was going/gone because they are both leaking haha. maybe they are gone i havent checked.
but yeah that vent line was going right to my diff. so i had a diff right full of diesel for 2 weeks.
havent opened it up yet or anything, just opened the inspection plug and had oil/diesel pouring out.
what do you think ill have to replace?
lesson learned indeed..
Harbin_22
3,858
Southern Indiana
:banghead: Gonna have to open it up and see. More then likely every bearing for sure, maybe ring and pinion too. Bet you won't do that again :poke:
ACiFiC
Oct 14, 2012
119
Canada
Lol, no I won't be doing that again. I don't know why it's vented to the filler neck, that's goofy.
I would probably be better off just getting a used rear end maybe? I bet this one is nice and clean everywhere haha
Dozerboy
4,892
470
TX of course
I think on my truck the diff vent was attached to the filler neck, but not vented into it. Your not going to get water into it very easy there I guess.
That sucks though:(
ACiFiC
Oct 14, 2012
119
Canada
So your rear end breather tube was vented to your fuel tank filler neck before you got in there messing around?
Yeah, the vacuum line was setup right beside the neck, I just assumed it went into the tank lol. I assume that isn't stock.
And definitely not going to get any water in there
Harbin_22
3,858
Southern Indiana
There is a kit from Northern Tool by RCS that taps your transfer tank into the actaul filler neck. Thinkin $75 and works like a charm. Comes with everything and you never hve to shut it off unless you are filling up.
ACiFiC
Oct 14, 2012
119
Canada
Probably look into that after I deal with this disaster haha.
I'm wondering if diesel would really dicker my seals up. I will pull my drain plug and see if I have shavings or what's the deal. Probably need a new pinion and what not.
1,866
Sorry to hear about it. We've all screwed up before. You wont know how much you have to replace til its opened up.
jevanb
Feb 28, 2011
159
montrose, michigan
just go to any hardware and buy a double 2inch hose connector (steel) and a fitting, and have somebody weld it on. thats what I did and cost me 15dollars
Harbin_22
3,858
Southern Indiana
That rig I put in, had a check ball setup where it went into the filler neck so it would close off when the fuel level got that high. Guess to keep it from using the cap as the final seal. It works great for someone not wanting to make their own stuff.
BIG PHIL
32 valve
Aug 24, 2011
172
Weatherford Texas
I'm going to look into that, I've overfilled mine a few times and it is infuriating. Thanks Harbin.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
o4dirtymax
86
CA
pop the cover off and see how bad it is. My buddy blew his rear end and we found a used one on craigslist for $400. Shitty that that happened but could be a lot worse
ACiFiC
Oct 14, 2012
119
Canada
That would be perfect haha. Wonder where I can get a ahold of something like this.
Just bought a whole new rear end? Like the entire axel?
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I have a friend that just regeared his truck, when you find out what you need post it up and i'll see if he has some of the parts needed.
