Hi. Sorry if the english is bad. But im from norway.
Just built my transmisson. with a ppe stage 4 kit and a tripple clutch converter.
But i have a problem cause the ppe stage 4 instruction sucks.
And was wondering about the c1 clutches. are the fricton supposed to head
Against the engine or rear axle?
In the instructions it says to put the frictions against the engine and so i did
Then put tranny back inn startet up. And so the truck goes in to gear
Reverse works. But when i put in drive. It goes in gear for about 10 seconds then jump to neutral.
So i checked instructions again and inn the pictures itt looked like the c1 clutc was supposed to be the other way. I pulled the tranny again. Turned the c1 clutch. And put it back inn.
And i still have the same problem. Tranny jumps to neutral and says range shift inhibited. And i got check engine light and a p0872 code.
Then i changed the NSBU with no luck. Also opened the valve house again and cleaned eveything one more time. Including a xtra check off the E valve. And all the solenoids.
And still no luck.
So hopeing someone can tell what way the c1 clutch are supposed to be. And if that could be the problem. Or somthing else.
Has also checked the wiring and plugs
Its a 2003 silverado lb7 2500hd with allison 1000 tranny
And still no luck.
