I have had head gaskets done under warranty. I bought studs and had them installed while it was apart. Truck is in now for a bad injector. Problem is that it will not come out, so they are going to take the head off the truck.
So I assume the studs will be good for re-use, I want to verify how they should be re-torqued. Also what lube can be used.
thanks:thumb:
thanks:thumb:
